NOTICE Notice: This is an old thread. The last post was 1460 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 4 of 4
Thread: Oil Leak from the water pump
    Senior Member Military Tribune Royphotog's Avatar
    Dec 2002
    Central California
    461
    About a month ago I replaced the O ring on the water pump because of an oil leek, that fixed that leak but now I seem to have an oil leek from the weep hole on the water pump. There is a rubber gasket on the inside shaft of the water pump and does not seem to be replaceable, at least I don't see it when I go to a schematic to look at the water pump. So the question is, if that rubber seal is leaking, would oil come out of the weep hole. I know that when the pump goes bad, that water will come out of this hole, but what about this oil leak.
    Dec 2002
    Central California
    461
    Just a note for any that have a problem with the water pump leaking oil, you can not get the oil seal by itself, it comes along with the water pump. $220 out the door from my dealer, but they got it the next day and I'll put it on tomorrow. Wall, just maybe the water pump was ready to go out and I adjust saved myself some more problems a long way from home.m
    Moderator Censor Silver's Avatar
    Jan 2007
    Colorado Springs
    9,501
    Re: Oil Leak from the water pump
    Quote Originally Posted by Royphotog View Post
    Good luck! When you tear it down take some pics.
    Hey ive had the oil leak aswell. But i was able to get all of the seperate gaskets and o-rings i needed.. Do you have a pic of where you are leaking oil from now?
  1. zzrbikes Water pump leak
    By clippedwing in forum ZZR1200 Tech Forum
    Last Post: 01-06-2012, 09:30 PM
  2. Water Pump Seals
    By Kooky in forum ZZR1200 Tech Forum
    Last Post: 05-16-2011, 08:35 PM
  3. Water Pump... Leaking oil?
    By MemoryRacing in forum ZZR1200 Tech Forum
    Last Post: 05-29-2009, 06:29 PM
  4. leaky water pump?
    By Afzzr12 in forum ZZR1200 Tech Forum
    Last Post: 11-08-2007, 08:06 PM
  5. Leaky water pump
    By Amp in forum ZZR1200 Tech Forum
    Last Post: 03-27-2005, 01:02 PM
Tags for this Thread
