Results 1 to 10 of 11
Thread: 1/5 throttle adapter
02-21-2012, 04:48 PM #1
I ordered one from the guy on the ZX10 site and may have it on by this weekend. The ZX10 crew swears by it even sev track bike guys. Ill post up some pics and a write up when it gets here....
02-21-2012, 06:05 PM #2
Re: 1/5 throttle adapter
Look forward to hearing what you think about the adapter. Been kicking that idea around myself.
tbolt
"I gotta drain the Super Dragon" - Tom Servo
02-21-2012, 10:09 PM #3
Uh what is it. Sorry totally out of the loop hear???????? peace
02-21-2012, 11:09 PM #4
72 degrees of rotation from idle to WFO. Quicker than the "old style" 1/4 turn throttle which goes from ho-hum to holy shit in a mere 90 degrees.
02-22-2012, 06:21 PM #5Senior Member Sensei
- Join Date
- Nov 2004
- Location
- foothills of the Catskill Mountains
- Posts
- 3,720
mmmmmmmmmmmmmmmmmm.......how do get one or should we wait for the feedback.......wait, I guess..nbk
02-22-2012, 07:01 PM #6
02-25-2012, 12:54 AM #7
Ok the conversion part is in. I hope to get it in and get a ride in tomorrow.....
Update....Install is pretty straight forward....Disassemble the throttle assembly and clip the adapter over the cable part of the throttle tube. This changes the radius of the tube and shortens the pull.
This then presents you with cables that are too short. You then take the plastic lock not on the cable at the throttle assembly and at the carbs off. Cut them out and you now have some adjustable play. Tighten those up as much as needed. If you still do not have enough you can trim the threaded end which is also plastic down 1/4 inch. I had to do that at the throttle but not at the carbs. I did a quick test and it opens the carbs completely in about 1 1/4 inch of throttle.. I put it all together and fired it up. No probs I just need to give it a test run this afternoon.....
Here are the how to's from the Zx10 site
http://www.zx-10r.net/forum/showthread.php?t=111247
http://www.zx-10r.net/forum/showthread.php?t=84589Last edited by JeffS; 02-25-2012 at 02:42 PM.
02-25-2012, 07:32 PM #8
Ok after about 50 miles of city, country roads and some twisties...."Why didnt I do this sooner" comes to mind....zero problems and a whole bunch of fun......
You will immediately notice the prior muscle memory you have for shifting is off. You get such good throttle response that it wants to lighten the front end. Once you quickly get used to it shifts are fast and no problem.
If you blurp the throttle when down shifting it is perfect it puts it right in the rpm range you want, at least it does for me.
For the middle aged squids they will love the ease to loft the front end, do burnouts and easily destroy traffic during those congested commutes....
02-25-2012, 07:57 PM #9
02-26-2012, 09:19 AM #10
Jeff, did you do this on a stock zzr1200 throttle?
WTB: SW-Motech Alu top rack w/Givi adapter
By Yossarian in forum Buy, Sell, TradeReplies: 0Last Post: 05-19-2009, 09:52 AM -
Murphs spin on adapter
By 02zed in forum ZZR1200 Tech ForumReplies: 14Last Post: 10-21-2007, 10:09 AM -
Power adapter
By racerx in forum ZZR1200 Tech ForumReplies: 2Last Post: 03-24-2007, 07:12 PM -
spin on oil filter adapter kit
By technut in forum ZZR1100 Tech ForumReplies: 17Last Post: 10-30-2006, 02:50 PM -
Oil Filter Adapter
By ninja0522 in forum General DiscussionReplies: 3Last Post: 01-28-2006, 06:20 PM
Donate
