Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    Administrator Miyagi-san Jack's Avatar
    Feb 2003
    Greenville, SC
    13,185
    Re: Silver's ready to ride!
    Just an FYI, 75% Pine-Sol (25% water) is great for cleaning carbs. Doesn't damage the rubber and really gets the crud off. I soak them for 24 hours and then take safety wire through the orifices. Then soak another 24 and they are usually good to go.
    Remember to use different size safety wire for the different size orifices and always pull the wire through a folded up piece of sand paper to remove any burrs your side cutters may have left on the safety wire. That way you don't damage any of the orifices.
    Also, you can remove carbon from the intake valves and chambers by removing the air box lid and running the engine at 3 to 4k while using a squirt bottle SET TO MIST ONLY shooting down each carburetor. It takes 4 or 5 cycles per cylinder to get the carbon out and you'll probably want to replace the spark plugs afterward.
    I've known old timers that would pour a cap full of water down the carb on a running V8. I strongly advise against that, especially on a motorcycle engine since water doesn't compress and you will bend a connecting rod.
    This is obviously after the fact for you John but I figure other readers may gain from it.
  2. #22
    Moderator Sensei Silver's Avatar
    Jan 2007
    Illinois, Galesburg
    8,256
    Quote Originally Posted by Jack View Post
    So you are calling me an old timer!
    Done the water thing many years ago.
    I cleaned the intakes with spray carb cleaner, an acid brush and compressed air. Closed the valves, sprayed and brushed then blew clean. I would have saved the original carbs for use but I think they have a bent pilot screw and the pinched diaphragms sealed the deal. Ultimately I'm just glad I'm ready to roll but I'll make you a heck of a deal on some crap tuning gauges Jack.
  3. #23
    Feb 2003
    Greenville, SC
    13,185
    Thanks John, but I use Mercury gauges. When I need to change the Mercury I just pour the old stuff out into my favorite fishing lake.
  4. #24
    Jan 2007
    Illinois, Galesburg
    8,256
    As long as you don't let small children play with it I think it's all good. Glad you're being responsible and safe!
  5. #25
    Feb 2003
    Greenville, SC
    13,185
    Quote Originally Posted by Silver View Post
    Have you ever seen a "3 Eyed Trout"? There's a bunch of 'em in this here lake!
  6. #26
    Senior Member Miyagi-san BIG O's Avatar
    Nov 2005
    Herrin Illinois (Southern)
    12,378
    How about a one eyed trouser snake?
  7. #27
    Feb 2003
    Greenville, SC
    13,185
    Quote Originally Posted by BIG O View Post
    I'm starting to worry about you Mike, You may need to change jobs.
  1. Silver...finally gettin the replacement Zed set up and ready
    By Silver in forum General Discussion
    Last Post: 04-17-2010, 11:57 PM
  2. I'm Ready...
    By rizzr in forum Off-Topic
    Last Post: 02-11-2010, 07:32 AM
  3. Big O, Want to Race? Silver’s ready to roll!
    Last Post: 06-13-2007, 10:56 AM
  4. Moonlight silver or galaxy silver, differences between Help
    By albertaboy in forum ZZR1200 Tech Forum
    Last Post: 03-15-2005, 10:58 AM
  5. Ready to ride finally!
    By Trackjunkie in forum General Discussion
    Last Post: 08-27-2003, 07:48 PM
Tags for this Thread
