Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: No spark??!!
    Senior Member Apprentice ak47's Avatar
    Nov 2011
    Famington N.M.
    161
    No spark??!!
    I need some help from the zzr experts here on the site with troubleshooting a lack of spark ( I'm guessing ). I went for a ride the day before and everything was fine. Tried to start it yesterday and nothing! It turns over and there is an occasional BLUB but it never quite catches. I have checked the fuses, battery connections, and gas with no problems found. I'm going to skin it today and check some more of the wiring and see if I am getting spark at the plugs. I am thinking ignitor problems but I am hoping for some feedback from you guys that may have already had this same problem to shorten my down time. Also, if it is the ignitor does anybody know where I can get a replacement for a reasonable price? I found a used one on e-bay but I would rather have new. I really need to go for a ride so please share your nuggets of knowledge!!!
    Ride, Shoot Straight, & Speak The Truth.
    VIP/Contributing Member Sensei reidmct's Avatar
    Dec 2004
    Hunt, Texas (Heart of the fabulous Hill Country)
    5,327
    Re: No spark??!!
    First, be absolutely certain that your battery is healthy and fully charged. People often say, "Well, if it's strong enough to spin the engine, it must be strong enough to make a spark!" Not true. The ignition system is more sensitive (less tolerant) to low voltage than is the starter motor.
    You said you checked the gas. What did you check? You're certain the level is above reserve?
    How To Cheat on Personality Tests
    1. When asked for word associations or comments about the world, give the most conventional, run-of-the-mill, pedestrian answer possible.
    2. To settle on the most beneficial answer to any question, repeat to yourself:
    (a) I loved my father and my mother, but my father a little bit more.
    (b) I like things pretty well the way they are.
    (c) I never worry much about anything.
    (d) I don't care for books or music much.
    (e) I love my wife and children.
    (f) I don't let them get in the way of company work.
    From The Organization Man by William Hollingsworth Whyte, 1956
    Nov 2011
    Famington N.M.
    161
    Re: No spark??!!
    Full tank of gas (no ethenol) and I replaced the battery last night. Still no luck. I have a multi-meter but I am not sure what kind of voltage readings I should be looking for at the ignitor and so on.
    VIP/Contributing Member Miyagi-san Danno's Avatar
    Sep 2006
    Southwestern Illinois
    12,360
    Re: No spark??!!
    Check your coil connections. One put on incorrectly can cause the motor to shut down as if out of fuel or no spark. Ask me how I know.
    No spark??!!
    Nov 2011
    Famington N.M.
    161
    Re: No spark??!!
    I havent messed with the coils or anything else on the ignition system since I bought the bike but I checked the connections on the coil packs and they look good. I am currently trying to remove the bottom bolts from the air box (no wobble joint small enough to fit) so I can check to see if I am getting good spark. I had a Suzuki VX800 that did this same thing and it was the ignition module. I also have a '66 Toyota Land Cruiser with a bowtie 350 that left me stranded in the boondocks because of a bad ignition module so that is where I'm betting my money at the moment. As soon as I can test the spark I will let you guys know what I find. Thanks for the response guys! I am definately not to proud to ask for help from those who know.
    Dec 2004
    5,327
    Re: No spark??!!
    You shouldn't need any u-joint fittings to remove the air box. Just push out the rubber plugs and you'll be able to put a straight extension right on the tricky nuts.
    Fingers crossed; it seems more likely the ECU is kaput.
    VIP/Contributing Member Master mehush's Avatar
    Feb 2005
    Orlando, Fl
    2,451
    Re: No spark??!!
    Kill switch on the right side bar gone bad?
    Dec 2004
    5,327
    Re: No spark??!!
    Quote Originally Posted by mehush View Post
    +1
    I couldn't edit my post yesterday to add kill switch and ignition switch as possible culprits.
    The manual goes on for several pages on inspecting the IC Igniter, detailing 8 different test procedures, several of them fairly involved. Hopefully, it won't come to that.
    Nov 2011
    Famington N.M.
    161
    Re: No spark??!!
    I didnt get to finish removing the airbox yesterday because I had a New Years bash to go to. I am suprisingly not hungover this morning so I am going to the shop to finish the task now. If the kill switch was bad it would not allow the engine to turn over, correct? Also, everything down the line from the key seems to be getting power (fuel pumps and such) but I'm sure that does'nt rule out the possibility of something amuck elsewhere. I will check the kill switch just for good measure. Once again thanks for the posts guys! I appreciate the help and input!
    P.S. I only have one plug on the airbox that allows removing the bottom bolts. Still cant reach the other two. Am I missing something or am I just blind?
    Moderator Master XXXXL's Avatar
    Sep 2009
    minden nevada
    2,351
    Re: No spark??!!
    if kill switch is bad, engine will not turn over
    No spark??!!
  1. Spark Plugs
    By jwb.ihm in forum ZZR1200 Tech Forum
    Last Post: 05-15-2011, 09:49 AM
  2. Oil on spark plugs
    By Hvacman750 in forum General Discussion
    Last Post: 05-20-2007, 05:20 PM
  3. spark plug?
    By ZEDHEAD in forum ZZR1200 Tech Forum
    Last Post: 11-02-2006, 10:06 AM
  4. Spark plugs -HELP !
    By worskeletor in forum ZZR1200 Tech Forum
    Last Post: 07-29-2006, 06:40 AM
  5. Which Spark Plugs?
    By tonyzzr in forum ZZR1200 Tech Forum
    Last Post: 06-05-2006, 07:18 AM
Tags for this Thread
