NOTICE Notice: This is an old thread. The last post was 2154 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: ZZR 1100 carb problems
    Junior Member Padawan
    Feb 2010
    8
    Hello,
    I am a new owner of a ZZR 1100 (2001a) and I have some problems with it:
    First, symptoms: it is realy hard to start the bike when the otside temperature falls below about 17 degrees C during the night. With or without choke, it just will not start. Basically I just have to let the starter turn the engine around for about a minute or more (ofcourse resting it for small periods during the time) pulling the choke lever on for periods and the pushing it off again. Then after some time, one cilinder will start fireing after I have pushed the choke lever off again and then I just have to play with the throttle and bring the engine to work.
    When it has starter for a small period, then it will start normaly.
    Also, when running on idle rpm, it seems to me that one cylinder does not work well.
    The bike is a bit low on power. I have compared it with a ZX-9r and a Blackbird by driving at the same speed (about 90km/h) in 6th gear and accelerating at the same time. Both other bikes will leave me behind quite quickly.
    First things first, what could be the problem of the starting issue? Since the bike starts normally when the engine has been started before, I thought that the reason should be in the choke. I have cleaned everything with carb cleaner and compressed air but have not reasembled it yet since I want to buy new o-rings.
    What is this whole A in this picture? Should it be opened or closed? http://mb1.live.hot.ee/rps/D/1650133.jpg?t=2
    Am I correct in guessing that the whole B is where the choke circuit takes the extra fuel?
    What are these things for http://mb1.live.hot.ee/rps/D/1650130.jpg?t=2 and how can i check that theu are OK?
    Cheers,
    Evar[/img]
    ZZRbikes.com mascot Jamesus Maximus jimmymac's Avatar
    Jun 2003
    KC MO.
    28,229
    Welcome to the Site, 3var.
    Someone should have some answers for you soon.
    KN, this ride's for You.
    Senior Member Consul reidmct's Avatar
    Dec 2004
    Hunt, Texas (Heart of the fabulous Hill Country)
    5,457
    Re: ZZR 1100 carb problems
    Quote Originally Posted by 3var
    I think that is a plug that fills a hole made during manufacture to create an internal channel.
    Yes
    They are the Fuel Cut valves. They are probably OK. But if you want to test them: Remove the valve apply 12 volts to the two wires (polarity does not matter). The valve rod should move between 2 and 2.5mm. If it moves more or less than that amount, the valve must be replaced. Always install the valve only on the carb it came from (do not mix them up).
    Have you done any other basic troubleshooting steps, such as checking compression and spark?
    Have you checked the fuel level in the carbs?
    Are you certain that your battery is good? (Have you actually had it tested, or at least checked its voltage?)
    Does the bike produce visible smoke when it is idling or when it is accelerating under load?
    How To Cheat on Personality Tests
    1. When asked for word associations or comments about the world, give the most conventional, run-of-the-mill, pedestrian answer possible.
    2. To settle on the most beneficial answer to any question, repeat to yourself:
    (a) I loved my father and my mother, but my father a little bit more.
    (b) I like things pretty well the way they are.
    (c) I never worry much about anything.
    (d) I don't care for books or music much.
    (e) I love my wife and children.
    (f) I don't let them get in the way of company work.
    From <cite>The Organization Man</cite> by William Hollingsworth Whyte, 1956
    VIP/Contributing Member Censor loic's Avatar
    Jun 2005
    Las vegas
    9,085
    also, check your plugs and plugs wire. start the bike with tank, airbox off, remove the rubber boot on 1 plug if the idle goes down then that cylinder ok, then to next one.
    some arcing may also
    occure in the plug well , apply some diastelic (or what evr its called) grease.
    if the carbs are the same on the 11 and 12, remove the floater, if i remember well, there is a screw and under that a metal screen. .
    the 11 and 12, under t
    Jun 2003
    KC MO.
    28,229
    Quote Originally Posted by loic
    Don't listen to Loic when He's been drinking!
    Jun 2005
    Las vegas
    9,085
    I was at work and posting from my phone....
    Feb 2010
    8
    Hi,
    Sorry for the delay, we have a lot of snow here in Estonia so could not get to the place where my bike is to work on it.
    a) First, I know that the compression was checked when I bought the bike. I don’t remember the exact values but I believe that they were between 8,5 and 9,2 (I don’t remember whether the units were bars or atmospheres) . What is the lowest compression that should worry me? I have to tool to check compression but I am not sure that its working. When I turn the engine around, the pointer of the tool moves to 10-12 but when I stop, it will stay around 8.
    b) I have not checked the spark but I will do it. How can I check the coils? I know that I should measure the resistance of the primary and secondary coils but what are the lowest values?
    c) I didn’t check the float level but after I put the carb back together, I will certainly do it.
    d) The bike does not smoke.
    e) About the hole A – should there be a hole or a plug? Mine has a hole there and it is connected to the hole (B) where the extra fuel for choke is pulled. That does not make any sense to me since as I understand, the extra fuel is pulled with vacuum but since A is above the gas level then it should only pull air. Or am I wrong?
    BR,
    Evar
    VIP/Contributing Member Master Leo's Avatar
    Jan 2005
    Denton, Texas
    2,524
    Do you have the bowls separated from the body of the carb? If so, is there an O-ring around a shaft that connects the bowl and the body? Not the gasket between the two. I am not familiar with the 1100 so this may not be part of the design. If this O-ring is present, examine them closely for nicks, breaks and other signs of wear or brittleness. If these leak they make that cylinder so rich it fouls. Hard to start, stumbles at low RPM but clears at high RPMs.
    "Here's to our men in uniform. ALL uniforms." Maximus
    "If you can't get it done on a ZZR1200, you can't get it done on a 14 either." CrazyTrain
    "If the space shuttle didn't keep exploding it would be a pretty good space ship." helodoc
    "Re: Turbo-Connie: It had to be done...
    Like putting a solid-fuel rocket booster on a wheelchair." Danno
    Jun 2005
    Las vegas
    9,085
    for the ZZR 1200 (I do not have the specs for the zx11)
    the compression:
    cylinder compression: (usable range) 879-1350 kpa ; (8.96-13.8 kgf/cm2, 127-196 psi) @ 320 r/min (rpm) with electric sarter
    Jun 2005
    Las vegas
    9,085
    still for the 1200:
    ignition system:
    pick up coil resistance : 380-570 (I dont know how to do the horse shoe symbol.....)
    3 needle arcing distance: 6mm (0.24 in) or more
    primary winding resistance (whatever that means...lol) 2.3- 3.5 (+horse shoe symbol)
    secondary winding resistance 12-18 K ( +horseshoe symbol)
  1. Silvers carb/IC Igniter problems improving...updated info!
    By Silver in forum ZZR1200 Tech Forum
    Last Post: 06-01-2010, 09:46 PM
  2. Possible Carb Problems
    By VIC in forum Newbie Section
    Last Post: 04-07-2009, 05:14 PM
  3. Carb Problems
    By Tron in forum ZZR1200 Tech Forum
    Last Post: 04-25-2007, 09:16 AM
  4. carb problems
    By crb987 in forum ZZR600 Tech Forum
    Last Post: 04-15-2006, 01:05 PM
  5. Self induced carb problems
    By bachaman in forum ZZR1200 Tech Forum
    Last Post: 01-31-2006, 04:36 PM
