NOTICE Notice: This is an old thread. The last post was 2753 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
Thread: Any of you OIL guys know who makes Super Tech Synthetic Oil?
  1. #11
    VIP/Contributing Member Miyagi-san KJ's Avatar
    Aug 2005
    GCS, LI
    13,354
    Quote Originally Posted by fastbear
    Warren Industries is the blender and supplier of Super Tech Oils.
    I have found 2 MSDS sheets on the oil.
    MSDS Here and Here
    Also found this in http://www.bobistheoilguy.com/
    TECH 2000 SUPER CONCENTRATED FUEL INJECTOR CLEANER -- FIRST BRAND
    SUPER TECH GAS LINE ANTI-FREEZE -- CRISTY
    SUPER TECH R&O ANTI-WEAR OIL ALL GRADES -- SPECIALTY OIL
    SUPER TECH RV WINTERIZER -- QUAKER STATE
    SUPER TECH UNIVERSAL PRECISE MIX 2-CYCLE ENGINE OIL -- SPECIALTY
    SUPER TECH SUPER CONCENTRATED FUEL INJECTOR CLEANER -- FIRST BRANDS
    SUPER TECH GAS TREATMENT -- FIRST BRANDS
    SUPER TECH FUEL INJECTOR AND CARBURETOR CLEANER -- FIRST BRANDS
    SUPER TECH & TECH 2000 WINTER FORMULA -25 WINDSHIELD WASHER FLUID
    SUPER TECH & TECH 2000 WINDSHIELD WASH -30F -- SOUTH WIN LTD
    SUPER TECH & TECH 2000 -20 WINDSHIELD WASHER FLUID -- SOUTHWIN T
    TECH 2000 & SUPER TECH SUMMER FORMULA WINDSHIELD WASHER FLUID --S
    SUPER TECH R&O ANTI-WEAR HYDRAULIC OIL ISO 46 -- WARREN DISTRIBUT
    SUPER TECH BAR AND CHAIN OIL SAE 30 -- WARREN DISTRIBUTION
    SUPER TECH UNIVERSAL HYDRAULIC TRANSMISSION FLUID -- WARREN DISTR
    SUPER TECH MINERAL GEAR OIL SAE 90 -- WARREN DISTRIBUTION
    SUPER TECH SAE 15W40 -- WARREN DISTRIBUTION
    SUPER TECH AND TECH 2000 20W50 OIL -- WARREN DISTRIBUTION
    SUPER TECH AND TECH 2000 5W30 MOTOR OIL -- WARREN DISTRIBUTION
    SUPER TECH AND TECH 2000 GENUINE 30W MOTOR OIL -- WARREN DISTRIBU
    SUPER TECH AND TECH 2000 30W MOTOR OIL -- WARREN DISTRIBUTION
    SUPER TECH AND TECH 2000 DEXRON III/MERCON AUTOMATIC TRANSMISSION
    SUPER TECH AND TECH 2000 TYPE F AUTOMATIC TRANSMISSION FLUID --
    SUPER TECH SAE 30 UNIVERSAL MOTOR OIL -- WARREN DISTRIBUTION
    SUPER TECH 5W30 FULL SYNTHETIC OIL -- WARREN DISTRIBUTION
    SUPER TECH FULL SYNTHETIC SAE 10W30 -- WARREN DISTRIBUTION
    SUPER TECH SYNTHETIC BLEND SAE 5W30 MOTOR OIL -- WARREN DISTRIBUT
    SUPER TECH SYNTHETIC BLEND SAE 10W30 MOTOR OIL -- WARREN DISTRIBU
    SUPER TECH ENGINE TREATMENT -- SPECIALTY OIL CO
    SUPER TECH STARTING FLUID -- VALVOLINE
    SUPER TECH 50/50 ANTIFREEZE AND COOLANT -- OLD WORLD INDUSTRIES
    SUPER TECH TILT AND TRIM FLUID -- WARREN DISTRIBUTION
    SUPER TECH MULTI-VEHICLE AUTOMATIC TRANSMISSION FLUID -- WARREN D
    SUPER TECH SYNTHETIC BLEND 10W40 MOTOR OIL -- WARREN DISTRIBUTION
    SUPER TECH UNIVERSAL 2-CYCLE OIL -- WARREN DISTRIBUTION
    SUPER TECH RV AND MARINE ANTI-FREEZE -- FOX PACKAGING CO
    SUPER TECH ENGINE DEGREASER -- HYDROSOL INC
    SUPER TECH CARB CLEANER -- HYDROSOL INC
    SUPER TECH WHITE GREASE -- HYDROSOL INC.
    SUPER TECH MULTI PURPOSE LITHIUM GREASE -- WARREN DISTRIBUTION
    SUPER TECH MULTI DUTY COMPLEX GREASE -- WARREN DISTRIBUTION
    SUPER TECH MOLY LITHIUM GREASE -- WARREN DISTRIBUTION
    SUPER TECH MARINE GREASE -- WARREN DISTRIBUTION
    SUPER TECH 0 DEGREE WINDSHIELD WASHER FLUID -- SOUTHWIN LTD
    SUPER TECH AUTOMATIC TRANSMISSION FLUID -- WARREN DISTRIBUTION
    SUPER TECH 75W140 SYNTHETIC GEAR OIL -- WARREN DISTRIBUTION
    SUPER TECH AND TECH 2000 GL-5 SAE 80W90 GEAR OIL -- WARREN DIST
    SUPER TECH AND TECH 2000 GL-5 85W140 GEAR OIL -- WARREN DISTRIBUT
    SUPER TECH FULL SYNTHETIC - ALL GRADES -- SPECIALTY OIL / PENNZO
    SUPER TECH OUTBOARD 2 CYCLE ENGINE OIL TC-W3 -- SPECIALTY OIL
    SUPER TECH MINERAL GEAR OIL SAE 90 -- SPECIALTY OIL / PENNZOIL QU
    SUPER TECH AND TECH 2000 10W30 MOTOR OIL -- WARREN DISTRIBUTION
    SUPER TECH SYNTHETIC BLEND MOTOR OIL - ALL GRADES -- SPECIALTY O
    SUPER TECH SUMMER WINDSHIELD WASH (WASHER FLUID 32) -- FOX PACK
    SUPER TECH +22 F WINDSHIELD WASHER FLUID -- FOX PACKAGING
    SUPER TECH 10W40 -- EXXON MOBIL
    SUPER TECH 20W50 -- EXXON MOBIL
    SUPER TECH R AND O ANTI WEAR HYDRAULIC OIL AW 46 -- SPECIALTY
    SUPER TECH SAE 30 UNIVERSAL MOTOR OIL -- PENNZOIL QUAKER STATE
    SUPER TECH AND TECH 2000 WINDSHIELD WASHER FLUID -25F -- FOX PA
    SUPER TECH WINDSHIELD WASHER FLUID -20F -- FOX PACKAGING
    SUPER TECH MARINE OUTBOARD 2 CYCLE ENGINE OIL TC-W3 -- SPECIALT
    SUPER TECH MARINE HIGH VISCOSITY 80W90 LOWER UNIT GEAR LUBRICANT
    SUPER TECH CORROSION CONTROL AND TRAILER WHEEL BEARING GREASE --
    SUPER TECH CONCENTRATED FUEL INJECTOR CLEANER -- PENNZOIL QUAKER
    SUPER TECH GAS TREATMENT -- PENNZOIL QUAKER STATE
    SUPER TECH POWER STEERING FLUID -- PENNZOIL QUAKER STATE
    SUPER TECH HIGH PERFORMANCE BRAKE FLUID DOT 3 -- PENNZOIL QUAKER
    SUPER TECH UNIVERSAL 2 CYCLE ENGINE OIL -- PENNZOIL QUAKER STATE
    SUPER TECH 80W90 AND 85W140 GEAR LUBRICANT -- SPECIALTY OIL
    SUPER TECH MARINE POWER TRIM AND TILT FLUID -- PENNZOIL QUAKER
    SUPER TECH SAE 30 UNIVERSAL HEAVY DUTY DIESEL ENGINE OIL -- PE
    SUPER TECH PERFORMANCE ENGINEERED HD SAE MOTOR OIL - ALL GRADES
    SUPER TECH HEAVY DUTY TRACTOR HYDRAULIC AND TRANSMISSION OIL -- SPEC
    SUPER TECH R&O ANTI WEAR HYDRAULIC OIL AW 46 -- SPECIALTY OIL
    SUPER TECH FUEL INJECTOR AND CARBURETOR CLEANER -- SPECIALTY OI
    SUPER TECH TYPE F AUTOMATIC TRANSMISSION FLUID -- SPECIALTY OIL
    SUPER TECH DEXRON III / MERCON AUTOMATIC TRANSMISSION FLUID -- SPEC
    SUPER TECH BAR & CHAIN OIL GRADE 30 -- SPECIALTY OIL / PENNZOIL
    SUPER TECH SAE 15W40 UNIVERSAL MOTOR OIL -- SPECIALTY OIL / PENN
    SUPER TECH PERFORMANCE ENGINEERED MOTOR OIL - ALL GRADES -- SPECI
    SUPER TECH ANTIFREEZE / COOLANT -- HONEYWELL
    SUPER TECH WINDSHIELD WASHER PREMIUM DEICER -30 -- FOX PACKAGIN
    SUPER TECH 5W30 -- EXXON MOBIL
    SUPER TECH MULTI LUBE -- HYDROSOL
    SUPER TECH OIL TREATMENT -- NATIONAL INTERCHEM LLC
    SUPER TECH 10W30 -- EXXON MOBIL
    SUPER TECH HD 30 -- EXXON MOBIL
    They laugh at me because I am different. I laugh at them because they're all the same!----KJ
    For those who ride, no explanation is necessary. For those who don't, no explanation is possible!!!---KRA(My Twin)
  2. #12
    Senior Member Censor Danno's Avatar
    Sep 2006
    Southwestern Illinois
    13,422
    Super Tech? Isn't that the stuff they make from the used oil I turn in every six months? If so, it's a combination of Quaker State 4x4, Valvoline Semi-syn and Mobil 1 4t.
  3. #13
    VIP/Contributing Member Master
    Jan 2005
    pa
    2,254
    Quote Originally Posted by 1KPerDay
    Quote Originally Posted by Midskier
    is Rotella T synthetic 5 w 40 still the "official" zed oil?
    I think I'm the only one who doesn't like it... transmission got noticeably notchier when I started using it. Next oil change it gets replaced with something else.
    nope there is two of us
    crap oil in a bike imo
    prophet or mobile or repsol full syn for me only
    Q: What was the most positive result of the "Cash for Clunkers" program?
    A: It took 95% of the Obama bumper stickers off the road.
  4. #14
    Senior Member Apprentice
    Mar 2007
    NW IN
    100
    [quote="Keendog42"]I used the Rotella T in the ZZR and it seemed to hold up very well. In the 14 it seems to break down prematurely so I went back to Mobil 1 15-50. Plus it's really not the bargain it used to be. At Walmart 4 quarts of Rotella T is $17 and 5 quarts of Mobil 1 is $24.[/quote]
    the wally world 15-50 5 quart jug for cars?
    I have rotella non synthetic in it now , and its due for a change and it shifts notchy too...............
    WWW.FOOTNGEAR.COM, Midskier = Midwest American Skier Boats, BKG = Busted Knuckle Garage, Barefoot Skiing = Waterskiing WITHOUT Skis. My BBW: 2003 Mystic Pearl Black / Chrome Wheels, Chrome Swing Arm, Chrome Grab Handles........
  5. #15
    Senior Member Praetor holtff1074's Avatar
    Feb 2007
    Bristol,Va
    2,555
    Re: Any of you OIL guys know who makes Super Tech Synthetic
    Quote Originally Posted by clausiam
    Quote Originally Posted by lifguardct
    I was wondering if anyone knows who makes Super Tech Synthetic Oil for Wal-Mart? I am thinking of using it in my truck. I may try Rotella Syn. in my 14, I used it in my FZ1, worked great...
    As for Rotella T there has recently been a reformulation that will replace the current versions. For the dino version this is on the shelves already and for the synth it will be soon. It's marketed as "Triple Protection". I have seen reports on several bike sites about people experiencing clutch slip after changing from old Rotella to the new Triple Protection stuff. According to Shell the new oil passed a JASO-MA test, but is not JASO-MA certified.
    So I think the jury is still out if the new version of Rotella T will be a good motorcycle oil the way the old version has been. I may either hoard some of the old stuff or go with a different oil until I see some more evidence one way or the other.
    Thanks for the Tip Claus as i'm closing in on a needed change and now may consider another choice though i must admit the Rotella has been great for me.
  6. #16
    ZZRbikes Ambassador-at-Large Imperator BIG O's Avatar
    Nov 2005
    Herrin Illinois (Southern)
    16,438
    Ironic that this topic came up.
    Just stopped by Wally World and picked up a jug of the synthetic Rotella.
    About $19.
    I guess if they change the formula I'll look into something else.
    Later Bros.
    Mike
  7. #17
    Senior Member Disciple
    Sep 2004
    Harrisonville, NJ
    942
    Quote Originally Posted by BIG O
    About $19.
    Later Bros.
    Mike
    Let us know if your cam tensioner starts to make noise during start up at approx. 2500 miles after you pour in the Rotella.
    Yes - The 5 quart jugs for cars. I've been running the 15-50 for about 10k now with exellent results. I even sent a sample to Blackstone Labs to have it tested and the additives were holding up great.
  8. #18
    VIP/Contributing Member Praetor Urbanus Moto's Avatar
    Aug 2006
    Sacramento, CA
    4,373
    I've been running Rotella 15-50 for over 20k now. I try (stress try) to change the oil every 3-4k and do a filter change every other change. I'm finding the oil is holding up very well even with the wet clutch. I also inspect the filter when I pull it and I'm finding absolutely nothing remarkable in it.
    IMO, for the price and lube ability...I'm liking the old Rotella alot. I'll have to look into the new formulation though.
    As far as the shifting goes...I installed the FactoryPro shift indent arm. The shift kit makes shifting smooth as a hot knife thru butter. I recommend it to everyone who feels there shift could be improved. But I have to warn you...it's a PITA on the Zed. I could do a post-up on it if enough people have an interest in that mod. Maybe a group buy could be in the works. Just FYI...I lifted the rear of the engine an inch.
  9. #19
    Mar 2007
    NW IN
    100
    15 w 50 mobil one for cars in a 5 quart jug is what it will be by next week
    (or 20 w 50) I'll use the left overs if any in the lawn mower
    I just feel the 5 w 40 is to thin anyway according to the book 5 40 is like good to 14 degrees f , and 20 w 50 is good 32 - 104 degrees f , the @#$% I'll be riding in anything below 50
    by the way I've used 20 w 50 synthetic in the mower for years
    smokes less and it doesn't smell when it does smoke ( 1968 wheelhorse Charger 9)
    can we restart Tire thread now....................
    Dan T
  10. #20
    Senior Member Sensei
    Feb 2006
    4,760
    Wuss...
    The Donger need food
  1. Super Tech Filters
    By fastbear in forum UK ZZR Riders
    Last Post: 03-15-2009, 08:16 PM
  2. Super-Visor ain't real super- the final results!
    By NATURALBORNKILLAR in forum ZZR1200 Mods and Upgrades
    Last Post: 04-29-2008, 01:41 PM
  3. Synthetic
    By atcjim in forum General Discussion
    Last Post: 07-15-2003, 07:56 AM
  4. Synthetic oil
    By wolfrnrr in forum ZZR1200 Tech Forum
    Last Post: 04-15-2003, 07:42 AM
